7 members (frogfarmer, Oldcaliforniakid, Stovebolt48, mason86, Woodcmiami, 1955 1 Series, Wally / Montana),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | On the 57, I have the door off and completely stripped out and painted on the inside. Question is: Will I be able to get to the screws to install the outside handle after installing the window glass, regulator and the glass run channel? Or do I need to paint the outside and install the outer door handle first? (I forgot the sequence I took it apart) Thanks.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I would do your paint and then first thing that goes in is your door latch and handle. If you put the window in first you can't get to the handle to put those two clutch head screws in.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | The door handle screws are accessable with the windows in, however it would probably be safer to do as Larry says, if you drop the front clutch head screw down into the door it will be real tough to recover it. I removed and replaced the handles on my '55.2 with the windows in. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I also installed my outside handles with the windows in, on my 55.2 3100. Dropped the screws a couple of times down in the door. All I can say is that it was a "ROYAL PAIN IN THE AZZ".
Brian | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Thanks guys. My doors are off and on a work table. But I could not remember if I removed the outside handle before or after removing the glass and regulator.
