0 members (), 110 guests, and 4 robots.
Topics128,183
Posts1,057,264
Members48,467
So I started the truck for the first time post resto. at idle the needle is in the middle, when the engine revs, it goes to discharge. The needle movement is tied to the engine speed. The more rpm, the more the needle moves toward "D". Any thoughts?
1955 1st Series 1/2 ton
Riding in the Passing Lane
With the engine off, turn on the lights. If the meter goes to charge You have the connections on the back of the amp meter reversed or the bat hooked up to pos. ground.
1972 Chevy c10 Cheyenne Super
YEP!!
Mo' Tater
It worked switching wires. Thanks
