| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 10 New Guy | | New Guy Joined: Apr 2006 Posts: 10 | So I have a 66 C-10. After sitting for a couple days, I have no brakes and no resistance in the pedal. If I take the cap off the master cylinder and put it back on, I have a rock hard pedal that instantly locks the rear wheels up when pushed. All original parts. No leaks that I have found. Any help would be great. I would like to fix it myself but not sure what the problem is. Booster? Master cylinder? | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | The vent in the cap is stopped up. Look for a vent and make sure it's clear. It is usually just a small hole with an off set hole in the gasket on either side.
good luck,
Les | | |
