| | | Forums66 Topics128,043 Posts1,055,612 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 4 Junior Member | | Junior Member Joined: Nov 2003 Posts: 4 | The hinge pocket on the driver side door post is rusted out - does anyone know where I can get a replacement. Also, when I cut the door post do I need to brace the cab - is the cab going to twist sag? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Almost all the Truck suppliers sell the lower door post. You have to provide your own threaded nut holder and pocket brace. You will want to make sure that nothing moves on you so bracing is a good idea. | | | | | Joined: Nov 2003 Posts: 4 Junior Member | | Junior Member Joined: Nov 2003 Posts: 4 | Thanks, I did buy the lower post but wasn't sure what to do with what was left of the pocket. There is hardly anything there to try and replicate. Even the lower bolt is broken off. Is the pocket something you have to try and fabricate? I have a friend whos doing my major welding and he's was even a little worried about that area.
Just know I'm new to this and a female and am doing this by myself. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Well, your hinge should give you a pretty good guide for the layout of the bolt holes and the new stamping should have a pretty faithful reproduction of the idented area. The reinforcement is a flat piece of heavy gauge metal that is bent in a big rectangle around the area. by the sound of it, your lower cowl must be still there, otherwise it would be visible.
In the links section, there is one to Chuck the Truck,s website and there are some good closeups of his work in this area. | | |
