1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#103435 06/22/2004 11:32 PM
rust is appearing on the seam around the beltline of my AD cab and I bel;ieve it can be blasted out with a "pocket" blaster. what is a good product to put in the seam after it is done before it is painted.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#103436 06/23/2004 3:54 AM
I had to blast that seam in my truck too. I then applied some "rust Mort" to kill any remaining rust . Then I sprayed that area with some DP40 "epoxy primer" and then applied some 3M seam sealer that I purchased in at the paint store. The next day I applied two coats of K200 a fill primer and that was it for the prep. It's been over 6 years and no rust bubbles have appeared so I guess it worked.
Joe
#103437 06/23/2004 1:33 PM
Anonymous
Unregistered
Anonymous
Unregistered
You must have deja vu three times now regarding this thread.
