5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#1034138 06/07/2014 9:03 PM
Today I finally got my newly installed 235 to run, and it runs pretty well. It has some features that the old 216 did not have and which I am not sure I will like, for instance the automatic choke. So far it doesn't bother me because the motor starts well enough without a working choke. But I would rather have a working choke.
Here is a picture of the carb New carb
One question is what is that hole for pointing west and what might I connect it to? Next question, where can I find instructions for how to adjust said choke?
I've got a slew of other questions too, but maybe I'll just start a slew of new threads.
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
That choke housing has a thermostatic spring in it that opens the choke after the engine starts. It does this by drawing heated air in through a pipe that connects to that hole. The other end of the pipe should sit inside a sheet metal case on the exhaust manifold. To adjust the choke you back off the three screws and rotate the black plate.
1951 1 Ton Completed
I have no sheet metal case on the exhaust manifold. Is this something I can make? Anyone have pictures of this application?
1953 Chevy 3100
1960 Volvo PV 544
Denny G
Sandwich, IL
Thanks Denny, you must have a heap of pictures lying in wait.
1953 Chevy 3100
1960 Volvo PV 544
Go to a FLAPS and ask for one Dorman makes one to replace it.
Pete
