0 members (),
122
Mod | | | Forums66 Topics128,131 Posts1,056,727 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | DELCO REMY 54 chevy starter. IS it possible to put a foot stomp start switch on this unit . The plunger is missing that fits into a new solenoid.IT looks like it might work because i have not seen any plungers used or new any where. ANY feed back .THANKS BJF | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Are you asking about putting a car starter on a truck? To the best of my knowledge all '54 trucks came with a stomp starter. My '55.1 panel did.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | In 1948 (and later years), a 6v solenoid starter was used on DD (step van chassis) trucks. In 1954 (and later years), a 6v solenoid starter was used on Hydra-Matic equipped trucks.
Foot pedal starters were standard on manual transmission 6 cylinder trucks up through 1959. 6v was used until mid-1955 in Chevrolet trucks (Task Force trucks were 12v).
I do not think you can remove the electrical solenoid mechanism and replace it with the mechanical foot pedal mechanism (but, I am not sure about this)
| | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | I found this starter at a yard sale .IT looked very close to the one in my truck.IT cost me all of $3.00. I am going to try putting a old foot stomp switch on it some how to see if i can get to work. THERE IS NO SOLENOID ON IT OR PLUNGER ,just the arm that engages the start gear to slide forward. The way i see it all i need is power transfer ,that is what the stomp switch is for ,if not i just blew $3.00. Thanks for the feedback BJF | | |
