2 members (Peggy M, 59 fleet),
87
Mod | | | Forums66 Topics128,096 Posts1,056,489 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Have a 235, flywheel has a triangle, a line,a circle and another line, assume these are timing marks as they have different color paint marks on them. Whats what? I put in a new distributor and cant get truck to run so I need to start from square 1 . Thanks in advance | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The / in U/C is top dead center. The BB is for setting ignition timing.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And what would U/C stand for literally Richard, Upper Center???? There was a discussion in another thread yesterday that should give you a simple way of dropping that distributor in and setting the timing pretty durn close to where you want it. At least well within the ball park so the engine will start right up and then you can zero in on the ball with a timing light. Initial timing: https://www.stovebolt.com/ubbthread...rds=Denny+Graham&Search=true#Post1033425 DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | UC and U/C mean Upper Center = TDC Top Dead Center
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well yeah!!!! Tiny already said that Timothy, question was, does the U/C really mean Upper Center???? Never cede that in any of the manuals, always was referred to as TDC, wonder why they dint stamp the flywheel TDC instead of U/C.
DG
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well I'll be danged, you would think after 72 years I would have noticed everything at least once. Guess I should read the fine print or maybe it's just my dyslexia but I've always read T.D.C. into it when referencing any of the manuals. Or maybe it's just that I have read Upper and Lower dead center and just forgot I saw it that way: http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0606.htm So from now on the meaning of those hieroglyphics on the flywheel should be crystal clear to all who stare in wonder. Think we've about covered this one, no? Denny Graham D|C in Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Tim, what character did you use for the vertical mark? I use the slash mark because I don't see a solid vertical mark on my keyboard.
| | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Not sure where you guys got the U C. I dont have those markings, and I dont have the BB. Ive screwed with this thing all day and cannot get it to fire. I pulled number 1 plug and got it on compression stroke and set dist to number 1 just so I get get it close. Its tries but fights hard. I have fuel , got spark, got good compression, its always the simple stuff that get you. I'm lost and beyond frustrated! | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Could have bad condensor or points, coil etc etc. If you have some spares I'd swap those out. Check ign wires, easy to cross 3 & 4. Vacuum leak will make you crazy also. If you have some B-12 Chemtool spray, it's great for starting help. Keep at it you'll find the culprit. I had one of these same frustrating events, took me three weeks to find the disolved paper fuel filter living in my carburetor. Best of luck | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Tim, what character did you use for the vertical mark? I use the slash mark because I don't see a solid vertical mark on my keyboard. | = bar (vertical bar) - keystroke: upper-case "\" (back slash) | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Have a 235, flywheel has a triangle, a line,a circle and another line, Not sure where you guys got the U C. I dont have those markings, and I dont have the BB What is the circle you reference? Do you have a pic? ...some Call it a BB... It's a circular dimple in the flywheel... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Different years and engine sizes had different markings.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Good point
The pic I posted above is off my 50, 139 tooth flywheel I was curious about the circle he mentioned
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Tim, what character did you use for the vertical mark? I use the slash mark because I don't see a solid vertical mark on my keyboard. | = bar (vertical bar) - keystroke: upper-case "\" (back slash) OK, that shows as a double vertical dash on my keyboard but it does display as a solid line. Thanks.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | OK so keyboards ain't the same either. My keyboard: \, shift and |, Works backwards from tclederman.....hum... oh well it works. My fly wheel has a delta/triangle, a BB and ....that is all folks. On a 55-59 235 but,...it is a 6 volt flywheel so ... who knows. My friends 57 235 has all three marks...so who knows. By the way his is a 12 volt as is the original spec for his truck. Not that that means much. After 55 to 60 plus years what has not been molested or changed on our trucks. And now I have to add keyboards..OK time for BEER!
Steve H
| | | | | Joined: Mar 2010 Posts: 10,290 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,290 | Well I'll be danged, you would think after 72 years I would have noticed everything at least once. Guess I should read the fine print or maybe it's just my dyslexia but I've always read T.D.C. into it when referencing any of the manuals. Or maybe it's just that I have read Upper and Lower dead center and just forgot I saw it that way: http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0606.htm So from now on the meaning of those hieroglyphics on the flywheel should be crystal clear to all who stare in wonder. Think we've about covered this one, no? Denny Graham D|C in Sandwich, IL In perfect Southern Illinois vernacular, read real slow like, "You shoulda knowed that". My wife's Granny from Olmstead used to say that to me many, many times. Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Taint got time to read real slow Carl, with all I got on my plate best I can do is skim thru the pictures.
Gonna be hard or darn near impossible for me to change my ways now. Even though the book might say Upper Center, Me pop called it T.D.C. as did everyone that I've rubbed elbows with over the past half century plus a few, must be the part of the country that I come from.
And once again, don't cha think this ones about burned it self out, no???? DG
| | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Dropped the nastiest distributor in I could find as a last ditch effort and the darn thing fired right up, runs great! Whatever....... Moving on | | |
