0 members (),
100
Mod | | | Forums66 Topics128,080 Posts1,056,317 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | I have found under the transmission cover plate some sort of gasket it's like a cardboard plate, it looks like it's maybe used to hold the gear shift foam seal and emergency brake seal up to the cover. I have looked through a couple of parts books and found no mention, can this be ordered from somewhere or do I need to make something up? See picture below. http://s1281.photobucket.com/user/d...MG_20140605_1126131_zps9d2872e9.jpg.html
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | Hi Tim; I just posted a picture of the cover and gasket. I have both foam seals for the shifter and Ebrake I'm looking for the gasket or what ever it is called. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I found the heavy paper gaskets for the access panel insufficient. I used 1/4" thick by about 1" wide neoprene weatherstrip tape as a gasket. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is this it: (1947-54) Transmission Floor Cover Gasket Set - as posted above by David, the last set I bought was like heavy roofing underlay/tar-paper? | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I didn't like that one Tim. It was so flimsy and I couldn't see where it was serving much purpose. I would like to see a one piece rubberized one. David's idea is pretty good. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy Gus, I just can't beat you to the draw now days. Thanks for posting the link. Yep, there was a heavy felt paper full sheet under my transmission cover, which was still stuck to the bottom of the cover with tar. It' was much heavier than the 30lb. roofing paper edge gaskets that the vendors are pawning off on us. I belive if the truck originally came with an SM420 from the factory it had the full sheet gasket under the cover. I've seen quite a few which had them but not to many were still in tact because water got under and or they were tore out just leaving the edge around the flange. My thoughts are that they served a dual purpose, first a gasket second as a sound deadener over the transmission. All that I've see were form fit to the cover shape and that's what I tried to duplicate on the new one that I made for mine. So Doyle what you got there is an original 4speed transmission cover gasket, which isn't being reproduced by any of the vendors. As I said, mine was a heavy felt paper I would guess about twice as thick as standard 30lb. asphalt impregnated roofing paper. Yours appears to be made of a treated paper but not treated with asphalt. It may be because it's a 1ton or because of which plant it was built in. I've been looking for nearly a decade but have yet to find a source for felt paper heavier than the 30lb. Anyone know of a source please let me know. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I cut thin strips of roofing paper to put between the pillars and the back of the cab (interior padding) but to keep them from falling out, I had to put three strips in each one. I would like to find a rubberized product to cut some of this out of. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A friend from Manhattan once gave me a piece of padding he had left over from his restoration. It was that thick felt padding like was used on the toe board, in the roof and that strip behind the seat around the belt line. Don't know where he got it but it was from one of the vendors I'm pretty sure. I've not seen it stocked by any of them since.
DG
| | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | Thanks Denny and all of the other comments or suggestions as to what to do here. A few years ago working in the LTL trucking industry we did haul around some cardboard/foam board for a concrete company I think it was used for insulation under a building pad, just wonder if they might have something that will work for this application. I don't know the exact mileage on my 50 but the more I uncover and restore it I think it really has to be very low mileage for something like this to survive. | | |
