1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I will not say a lot about this subject except .............. Jerry You said alot Jerry. All subsidies suck in a free market system.... IMHO | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Here we go,"SUBSIDIES SUCK IN A FREE MARKET SYSTEM" FREE MARKET SYSTEM? HOW much are we subsidizing the Big Oil companies? Is Ethanhol still being subsidized? Did we not "Subsidize" by sending troops to Iraq, sacrificing our sons and daughters in the search for weapons of mass destruction? All off budget! Who gained besides some stockholders of Halliburton, a few politicians and BIG OIL? I am willing to continue this discussion in PM's if you think your able to P further than me. Jerry Jerry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | politics to the spoon please, where the bouncer can more easily delete your peein contests
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Interesting experiment Jerry, that is the closed jar and open jar idea. Ya got me pouring as I type here before the sun comes up. Good day to get started on that cuz it started raining this morning and will be most of the day, humidity will be up in the high 70-80% most of the day and more to come later in the week: http://www.pbase.com/dennygraham/image/155946647 As fur as the old containers go, I guess I'm the lucky one there also. Old tank in truck, simply put fresh gas in her the day I picked her up 30 miles from here and that's all I've been doing for the last nine years is top her off with E-10. Almost all of my gas cans are old ones that I've had since I got married and bought my first house, forty years ago. Lucky again I guess, never had a problem with fueling from them either. I do now and always have made a habit of keeping a lid on it with any volatile liquid: http://www.pbase.com/dennygraham/image/155946687Denny Graham Mr. Lucky in Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Jon, I don't understand the take on Monel. Monel is highly resistant to corrosion being over 60% nickel, copper and some iron. It's also difficult to machine because of it's tendency to work harden. It's specified in especially corrosive environments such as marine and chemical industries.
Your suggestion that the Viton is a better choice for a carburetor needle is backed up by the rest of the automotive industry. I think the idea that a metal to metal seal is better stems from the fact that they are recommended for use in 'High Performance' applications where exotic oxygen rich fuels are being used so some may think that would be more durable when applied to their Rochester 'B'.
Viton tips on needles have been around ever since I can remember. They were in the premium rebuilding kits back when I was an automotive parts men in the late 50's and on. I would urge anyone new to rebuilding carburetors to heed your advice about staking the seat to break the sharp edge since Viton is principally a rubber.
Denny Graham Sandwich, IL
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If the viton seal works for you then I highly suggest you keep using them.
I know what works for the vehicles I work on and plan to keep doing what I know works well.
But saying E-10 is a good fuel is talking with blinders on.
Fuel economy goes down, rubber parts are affected whether or not any one else seems to think so.
As for sealing the tanks with the gas cap, most of these old rigs use a vented gas cap. Not usually a problem as long as the vehicle is run regularly.
But if you've not had problems with E-10 fuel, you indeed have been quite fortunate. | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | The open/closed jar experiment is incomplete unless you also have a second set with ethanol free gas in them started at the same time side by side.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The open/closed jar experiment is incomplete unless you also have a second set with ethanol free gas in them started at the same time side by side. Denny likely chose to only use two jars because he only has but so much room on his work bench for all of the now loose, salvaged nuts and bolts with which he can't seem to part. (I tease only because I too am similarly afflicted.)  'Peachy'
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I have the same problem but I'm envious of Denny because he has a lot of neat, cool, useful "stuff".
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nope, both wrong. Always a corner at one of the bench's where you can shove somethin' over. And the fuel in question was E-10 and it's hydroscopic affinity to absorb moisture out of thin air. I have since I started this, thought of a couple more scenarios. Not to late since I'm only a day into it, but I'm gonna add a jar that has been Sta-Bil'ized. And since I've got more Smucker's jars than I well ever use for nuts and bolts, I'm going to make another matching set and place them out in the direct sun this summer. Also gonna make one with the lid on it but just a hold punched in the top to allow it to stabilize with the relative humidity but not evaporate out so fast. Should be interesting to see how it turns out.
Oh, I gotta throw this in also. I haven't used my Echo chainsaw since last summer. Just parked it on the shelf with E10 fuel from the middle of the summer in it. I had to cut off a 6x6 yesterday and one pull with the choke on and a second one with the choke off and she came to life just as she always has and ran just fine. I wish I could master the videos like Gus has done to better show that this isn't BS but I really haven't had any problem with E10 even when it's a year or more old.
Now I can't let it dye with out saying, Roy ya sound like you've had your share of problems with your fuel and I do feel for you guys down there in the south. But we indeed must be quite fortunate up here in Northern Illinois cus that's all they've been selling in the service stations for decades now up here. And I've never seen a car, truck, motorcycle, lawn mower, tractor sitting off the side of the road in all these years, nor have I heard any average operator complain about the way their vehicle ran on the gas they just pumped into their vehicle. Seems the only ones that I've heard complaints from are the guys that are constantly tinkering with their engines and blaming the problems on the fuel. DG
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The problem I had was from when I let the truck sit without driving for 12 weeks ...bad gas... ...bad gas... ...bad gas... Now this happened the first summer I had the truck running. I let the truck sit in the garage over the summer without starting it. Temp's over 110. Since that happened I now put stabilizer in the summer when I don't drive that much and I make it a point to start and drive the truck a least every week. I try to put fresh gas in. The key with the new gas is to drive. At least in my area. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I let me 42 Ford still since last September, fired it up for the first time on June 2nd. Not a single issue. The gas in the pulsator dome was caramel, and I after I primed the carb, it started on the second rotation. I just don't see the huge problem with ethanol fuel. HERE IS AN API REPORT ON ETHANOL FUELS What's curious is that some engines failed even with E0 (ie pure gas!) and they never stated WHAT motors were used... just 'test engines'. Most failed emissions, but others failed valve wear and compression. But its unclear if these were production motors or 'test case' motors. One test motor was noted as the design was 'not appropriate' for the test. | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | I drained my tank.It was clean in there,no residue of any kind.Cleared out the fuel lines and rebuilt the carb.While doing that I discovered that the power piston was frozen in it's bore. I freed that up and put it all back together with a filter before the carb. I poured in 5 gallons of "real" gas from a local station that sells it.Fired up the truck and adjusted things. This morning I started it up again and headed down the road. I drove all the way into town,turned around and came back home feeling like a 6 year old on Christmas morning. It runs and drives beautifully.I need to tighten up the front end a little but I'm on the road finally.Put 6 miles on my brand new odometer. My plan is just to not use fuel with alcohol in it.I don't need to and my truck doesn't like it.---Jack | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Denny - I am aware of the nickel content of the monel steel. I was very surprised at the rust on a steel valve the first time I saw the rust. Since then, have seen MANY more. And I can assure you that I did NOT paint the little brown spots on the valve in the picture  We have tried unsuccessfully to locate a supplier for triangular shaped monel steel in order to manufacture these valves for those who still think they are better. And yes, I am aware that the Rochester B used a square valve, which will work for low fuel demand; but the triangular valve is necessary (or machine feed holes in the seat) for larger or performance engines. The fuel flow past the square valve is insufficient for that type of engine. We can acquire the square material but the cost is ridiculous. The effect of ethanol on neopreme seems to be that the neopreme will "harden" if exposed to ethanol and then allowed to dry. This effect will kill the neopreme accelerator pumps because the skirt of the pump can no longer flex, but does not harm the sealing property for a fuel valve. This is just one of the reasons why we try to inform enthusiasts that their best form of preventive maintenance is to start the engine at least once per week, preferably more often than that. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bean running a simple experiment since June on the E10 fuel that we have around these parts. All the jars were filled to the same level. Working from the left is fresh fuel bought in June, 2014, in a sealed jar. The second is fuel bought in the fall of 2013 in a sealed jar. The third is fuel bought in the fall of 2013 in an open jar. All three kept inside. The fourth is fuel bought in 2013 in a sealed jar, the fifth is fuel bought in 2013 in a vented jar, the last two were left outside in direct sunlight from the beginning of the test: http://www.pbase.com/dennygraham/image/156934846There is no sign of separation, there is no sign of water absorption, there is no sign of residue in the fuel that has evaporated. DG
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I haven't seen any effect in my old trucks, they just start right up after sitting for a while. Those old 235's seem to just want to run. On the other hand, our wakeboard boat, with a 350 inboard, LS3 engine runs really rough every time fuel sits 3-4 weeks....always with stabilizer. I'm going to start using that green ethanol stabilizer to see if it helps. Interesting experiment thought Denny, a real head scratcher.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Only reason I did this was because I'm always hearing about how the E10 absorbs water, or separates or leaves residue behind when it evaporates or a dozen other problems guys blame on the fuel. One thing that I didn't do is fill a steel, an aluminum and Die cast cup with some to see how long it would take them to corrode. Of course it's kind of hard to find cups made of each, but that's all for another day.
I'm not saying that it doesn't have it's problems, just that I feel from my experience that they are grossly blown out of proportion.
dg
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've never had an issue with months old gas. The problem I had was with 20 YEAR old gas. I agree that the makers of fuel stabilizers probably make the issue to be more dire than it really is in most cases.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The only month old gas in the test Richard was the single jar on the left. The rest are all from around this time, maybe a little later, last fall. And with out going back and rereading six pages of comment, I believe there were warnings about not using E10 more than a few months old. DG
| | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | For those of you using Stabil in E10, either buy the new stuff that is made for alcohol, or the marine grade, or use a double dose of the old stuff. | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | After reviewing Denny's jars of fuel I believe I would side with him. I too have seen "bad gas" in different application but feel that the problem came from contact with other materials to create the issue. Contamination from dirty fuel tanks, water in tank from time or cold storage when tank wasn't put away full, old rubber fuel lines, decomposing old fuel filters or cork gaskets. I still use Sta-bil but not as worried as I use to be.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The problem I had was from when I let the truck sit without driving for 12 weeks ...bad gas... Now this happened the first summer I had the truck running. I let the truck sit in the garage over the summer without starting it. Temp's over 110. Real world experience Could of been a bad batch out the pump I don't know. That red cap jar looks close to what I found. Wonder if that gas would start anything? My down time is opposite from many of you. I park mostly in the summer and drive all winter. I start the truck more often now and try to add fresh gas over the summer. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | DADS, re Dennys test samples and your experience, note that our tanks are vented to the atmosphere, like that red cap jar that was in the sun so subjected to heating and variation in day/night temps .... obviously variations in what folks experience are variations in their exact equipment and environmental conditions
one way to deal with extended down time is to always top off the tank, apply an unvented cap, use the shut off at the tank, then run the engine until the carb is dry - what I do with seasonal small motor things
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | one way to deal with extended down time is to always top off the tank, apply an unvented cap, use the shut off at the tank, then run the engine until the carb is dry - what I do with seasonal small motor things Bill Thanks. That's good advise and makes sense I tossed out a 1 year old gas tank because of that mucked up gas. Hard lesson learned Around here on the pumps there is a disclosure on them. Certain times of the year fuel may contain ?% of ethanol. I don't remember if its summer or winter? That was the only time it happened. | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | I guess Roy and I are the only ones with issues. I have a chevy II with a totally new fuel system (tank, sending unit, hardlines, fuel pump, carb). Rebuilt 327, 4 speed. Let it sit couple years as life's events got in the way, even had Stabil in the tank, and when I decided to get back on it, noticed some black goop under car. checking fuel lines, soft and spongy, stinky tank, drained it and something akin to stinky bad molasses came out (remember, new tank). Went through 2 gallons laquer thinner cleaning adn cleaning out lines, replaced fuel lines, dang, fuel pump affected too, but carb was ok. This was in closed outbuilding, no heating/cooling and Alabama diurnal cycling. Same thing happened couple years later to my 390 galaxie. New tank/sending unit, new fuel lines, new pump, new carb, fooled around and lost track of time and let it sit too long, again with the soft swollen fuel lines and stinky molasses gas, so cleaning again and again, rubber diaphram in fuel pump shot. I have a friend who does small engine repair, says he sees alot of small engine issues with little rubber lines that sit in fuel tanks swelling shut or getting soft and pulling shut and they won't run. Back to my Galaxie, carb (previously rebuilt) shot too, so I ordered a new Holley 600, gee the tag hard wired to it said "use of ethanol blend voids any warranty". If there is no problem, why the tag? Now, I must admit, was recently given a Lebaron by a buddy, it has LOTS of issues, drove it home on 3 year old gas that seems to have no problem. Maybe it is my 2 cars being stored in unheated/uncooled building and whereas his Lebaron was stored in open air pole barn? don't know. But, I am glad for you guys that have had no issues, but just becuase you haven't doesn't mean it isn't real. Maybe it's the blend happening at the tanks Roy and I buy from or where the Holley guys buy from? don't know. But, it is real. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | They make a barrier hose now for fuel that is supposed to resist the effects of the ethanol.
Have they changed the rules on marine engines and ethanol fuel? Probably okay if you don't have a fiber glass tank. Or was that what the problem was? Not a boater and don't remember just what was happening with them.
I know every year I get the joy of replacing the little primer buttons on our push mowers and weed eaters. I watch the rubber fuel lines on my air cooled VW like a hawk and change them regularly. Too many engine fires due to hoses breaking down.
I'm glad others aren't having the issues I've seen around here. Could be we really are getting bad gas while everyone else is doing okay.
I do know my VW Passat would average 32 mpg on unleaded regular fuel, but when I could no longer get that around here and had to buy the E-10, my mileage went to 26mpg. Not sure how that is an improvement. Others say their mpg hasn't dropped. So it has to be the blend we're getting rather than the ethanol content. Hmmm... something to ponder. | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | The marine issue is the damage to fiberglass tanks...quite expensive to fix if the tank is built in.
I have a number of small engines here in FL. I finally added a fuel shut off to each one. Run the carbs dry, and then siphon the fuel out of the tank before storage. I even bought spare carbs to speed up the repair process when necessary.
The only automotive engine I had sitting for several years was a 440 Chrysler. I did add some Stabil. It always started and ran. Eventually I even sucked out most of the gas, and ran it through my lawn tractor, which oddly enough, has never had a problem.
Alcohol packs less energy than gasoline, and will definitely eat into your mileage. No dispute there. E85 can cause a 30% drop. Some states banned alcohol in summer because of the vapor lock problems.
| | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | I'm very thankful they built a new gas station about 8 miles away that stocks non ethanol, it is only 87 octane but better than nothing. That is all I run in my carburated and lawn stuff now. My brother ran a small business for couple years of lawn care, he said it was amazing how much better his small engines cranked on ethanol free gas. I still use ethanol on my fuel injected cars and will even use it on my mower, because I don't put in much and usually run the tank out in a week or so. I checked mileage on my daily driver, a Marquis, and my mileage was same on ethanol versus non, but the car felt like it had more power on non ethanol. Just some more scattered thoughts from a scattered mind.... | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | At least I understand the "scattered mind" LOL | | | | | Joined: Dec 2013 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 117 | Guys, isn't there an issue to consider when 'running the carb dry?' If done with any frequency, what effect will this have on the fuel pump? Isn't the fuel pump cooled by the fuel running through it? I understand that the pump would run dry for a very short time. But still... Also, if running the carb dry is the way to go, what about the pump plunger (e.g., the Rochester B)? I wonder about letting the leather dry out. And does running the carb dry clear out all of the fuel, or does it leave some which will then turn to varnish? Maybe there is something one can spray into the carburetor when parking the truck for some time? Otherwise, it seems to me that there is no other choice than to remove the carb, clean it out, and oil the plunger. Somewhat tedious if one ends up having to do this anytime the truck will be parked for several weeks, etc. -Alden | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Any cooling at the pump would only be for modern electrical high pressure pumps. That is why they are in the tank. Good question about the accelerator pump..any thoughts?
Steve H
| | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | Alden, I have never witnessed the problem on an automotive carb. Leather is pretty resilient. However, with the small engine carbs we have been also discussing, it can be a problem. You take your choice....dried out paper gaskets and seals, or gummed up carburetors. Luckily most small engines today have rubber and plastic gaskets instead of paper. | | | | | Joined: Dec 2013 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 117 | Steve H, thank you. Shows you what I know about pumps! I will have to find the time to better familiarize myself with my mechanical pump. Obviously, the oil in the block adequately tends to the pump's internal parts. As for keeping the leather in the accelerator pump from drying out, I am hoping that, except for rather long term parking, it should stay soft. I think if it be soaked in some oil during maintenance, that, along with it being somewhat deep in the carb, should keep it safe and sound. I intend on examining one of these leather plungers to see how difficult it would be to manufacture them at home. Hmmmm. I seem to recall my old lady doing some leatherwork recently. I will have to check out her crafts box when she goes out...
