5 members (MRMEROTH11, Eisenholtz, TexasA&M48Truck, Wickedbass, Gdads51), 66 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#1033539 06/05/2014 4:14 AM
Hey I just got this old gril running and runs good was planing some chores around the place now the clutch is slippin like a mother any suggestions to get a little hold without replacing it
Manual or hydraulic? If yours is manual,there should be an adjustable threaded rod,connecting your clutch arm to the bell crank. try threading the rod,(counter-clockwise),to gain more friction. The arm should move toward the engine. If that doesn't help,it may be time for a new clutch. Someone else may have a better suggestion. This is just from my experience. Hope this helps.
Mo' Tater
if it can't be adjusted up as Willy sez, you're on to replacement
So I crawled under the old girl this afternoon and discovered all the friction material is gone on the pressure plate side. Would been nice if it had done it before I loaded the dang thing!
