| | | Forums66 Topics128,041 Posts1,055,489 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 32 | I am putting a rear end out of a 65 Chevy 1/2 ton in my 1949 Chevy 1/2 ton. My only question is what size u-bolt do I use. I know it's a 3" tube, and I can figure the length, I just need to know the actual bolt diameter (ie: 1/2", 9/16", 5/8", etc). I do not need a kit. I already have the perches and shock mounts. Any suggestions on where to buy is appreciated too. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I believe the size is 5/8"-18NF on most of the smaller trucks. I know Speedway and Summit Equipment carry several sizes and types of u-bolts for both street and racing applications. | | |
