1 members (2-Ton), 111 guests, and 2 robots.
Topics128,105
Posts1,056,542
Members48,448
#1031460 05/27/2014 12:33 PM
I purchased a new Omaha Standard steel frame wood floor flatbed for my 1.5 ton '46 chevy. Just wondering what some of you guys think is the best way to attach the flatbed frame to the truck frame? I have seen multiple ways, just looking for the best. Thanks in advance.
The most effective and least expensive route,would be flat 1/4" stock,mounted with 4 threaded rods per mounting point. you could also have "U"-bolts custom made,drop them down from the bed rail,and bolt it with the flat stock,to the bottom of the truck frame. The "U" bolts are usually installed in pairs,with a single piece of flat stock,with 4 holes drilled to accommodate the bolts. This reduces the chance of the bed "walking" on the truck frame,plus it gives added security. Depending on the length of your bed,most have three or four mounting points per side. Don't forget your (lock) washers,or "Loctite"! Hope this helps.
Mo' Tater
These guys can make you a quality u-bolt for a reasonable price. They run a good company.
http://www.stengelbros.com/
Lots more pictures
A hard wood stip over each frame rail.. about 1/2 in thick and plates and bolts. I would also advise a filler block if the frame is a c-channel so the flanges do not bend down.
You could also get fancy with shear plates... but unless its a work truck 4 hold downs is usually enough.
