| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 9 New Guy | | New Guy Joined: Feb 2014 Posts: 9 | Hey there guys, I have been picking away at my 1957 gmc 9430 project and came upon yet another question. I am in the process of swapping out the rear end and getting the suspension all set up. Now, for the question. Looking at the rims on the truck, they appear to be original, I think they are 17", and have gmc hub caps on them. Is it possible these are not split rims? I see somewhat of a ring around the outter edge of the rim, but that ring is solid and doesn't have a slit in it like I have seen on the few other spilt rims I have ever seen. Any thoughts? Thankyou in advance | | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | 17" will be a tube-type multi-piece wheel, and 17.5" will be tubeless one-piece.
They may be three-piece wheels (I know that at least a lot of the 60-66 era 17" wheels were). If they are, there will be a big snap ring in between the outer rim/ring and the center/rest of the wheel. EDIT: And the outer ring/rim will be a solid/continuous ring as you described.
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: Jun 2005 Posts: 1,004 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,004 | My 59 1T has 19.5 wheels.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Feb 2014 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 46 | my 52 1 drw had 7.00 or 7.50 18".whole truck is bone stock.vew did your rig come out with that size rubber? | | |
