| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | I'm picking up a 1953 216 this weekend and plan on restoring it back for my 1937. Just curious what changes occurred over the years, and what accessories I'll have to look for to make it right. Anyone know?
-Doug Frantz 37 Chevy 1.5 ton and various other scraps of iron still on the road
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | I have 2 1937 216 complete engines if your looking for date coded engine to put back it your truck. one is from my 1.5ton and the other I don't know what it came out of.but it has low miles on it. Dan http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Your over near Harrisburg, PA, I'm over toward the WV border in western PA.
I don't know if they still had the horn mounted to the intake manifold or not on those engines. If the intake has a protrusion on the top with 2 holes it is for a horn. I take you want it to look like a '37 engine?
John | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Dan, what is the engine you are working on in the pictures? GMC engine? Watch parking the Chevy so close to the Ford, don't want the Chevy catching rust..... LOL John | | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | I'll look for the horn mount/material to drill. This is a slow going process but I finally have the space and money to work on the truck (and other projects), and time will be opening up a little bit as we finish renovation of our old farm house in York county.
I have a 56 253 that came with the truck and I understand it's better, I also know they make dress up kits to look like a 216 at first glance. I am not 100% sure what the project will be (how much restoration vs restomodification), but I like the idea of the original motor setup. I do plan to actually use the truck to go to farmers markets and sell some produce from the farm. I figure it's "free" marketing.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Whitelightning, lol yes GMC, my 37 F33HD GMC COE engine, its a 286 , and where do you see any ferd stuff in my pictures? lol, if there was a ferd next to any of my GM stuff I would have to hot tank them before I could work on them. unless your talking about the 1914 model T, my 36 coupe/pu is parked next to it, I will have to build a wall now to keep the germs from jumping ship to chevys. lol http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Frantz, if you need any pictures of what the 37 engine should look like let me know and I will take some pictures of the 37 1.5 ton engine for you,Dan http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have some of the changes listed on my Blog. I have not added it to the list, but there also were some water pump changes between 1937 and 1941.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | Thanks Dave. That's exactly the info I needed!
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The valve cover for a '37 216 will not have a provision for an oil cap. The draft tube may be different and the top of the draft tube has a cap on it for adding motor oil. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Don beat me to it. The '37 216 used a Carter W-1 carb. I'm not sure if the '53 used that as well or if it came with a Rochester. I can furnish you with a lot of pics of my '38 216 which would be identical to your '37.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | My original 216 project from 1950 had the horn mounted on the intake, and a Carter carb. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | My 49 3100 w/original 216 has the horn mounted on the firewall and a Rochester B carb. I'm absolutely sure the horn came from the factory that way but the carb was cleaner than the rest of the engine so it's possible that it is a replacement. I would like to add that the Rochester B works great, just like it was made for the 216.... Dave | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The spec sheet for my '38 says the same thing about being on the side of the cylinder head. I think it's just the way they said things back then Tim. It (my '38) is, and always has been, mounted to the intake runner forward of the carb. '38 spec sheet. Horn.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for the clarification/information, Tiny
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I have a question about the domed pistons. Was the volume of the chambers in the head of that 216 increased compared to later, flat top piton engines? Will the domed pistons work in the later engines (if you could find them)? Carl
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 1937-40 dome pistons hit the 1941 and later heads. If you use a 1937-40 head with flat top pistons you will end up with very low compression.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | I expected some differences, it's impressive how many improvements occurred over the period. I am appreciative for all the responses!
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | As Brad noted above your '37 would have had the electrolock. While you can find them on ebay regularly the coils that work with them are pricy and sometimes hard to find.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The 1937-40 dome pistons hit the 1941 and later heads. Nothing a little machining on the dome couldn't fix, right? I'd like to see how much pounding the babbit can take.
