3 members (cmayna, TUTS 59, 1 invisible),
146
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | A year ago I had the 3.55 gear upgrade and they put a speedometer adapter on. Just recently my speedometer quit working though connections hadn't changed. I took the gauge out and lubed it, also lubed the cable, and the odometer which never worked, put it back in and they both worked for about 1/10th of a mile. I totally don't get it. It works fine when I spin it, and there is only one way the cable can connect, right? What am I missing here??? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Does it rest at 0 when not in use. Will it return to 0? | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Currently it rests at zero all the time and the odometer is stuck at 1/10th mile beyond what it had been. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | It works fine when I spin it, and there is only one way the cable can connect, right? What am I missing here??? Only one way to connect it Make sure the connection nut on the back is not to tight. You can pull the inner cable to inspect it. I'm sure you already did that since you stated you lubed it. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If the needle goes past 0 like this ...QuickTime video... Then the speedo is broken. It should stop like this ...QuickTime video... | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Thanks Dads50. Hadn't thought connection could be over tightened, I'll turn it back a notch and see if that's it. BTW does the same apply to the trans connection? I think the gauge stops like the second video & that it's good.
Having a forum like this with guys that are willing to help us mechanically challenged owners is fantastic! I always learn something. Thanks again. | | |
