Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TUTS 59, walter74, 1955 1 Series, 51sub, farmallb, 1 invisible), 42 guests, and 2 robots.
Topics128,005
Posts1,055,256
Members48,418
#1031582 05/27/2014 10:06 PM
I have replaced the wheel bearings on my 53 3100 with roller bearings now how tight do I do I tighten the spindle nut? Assembly manual says start with 400 inch pounds but this just seems too tight.
twheelock #1031594 05/27/2014 10:35 PM
I usually go by "feel" on these. Tighten the nut until there is no or little movement when trying to move the wheel by pushing on the top of wheel and pulling on the bottom (while rotating the wheel). Look at your cotter pin hole and adjust (tighter or looser - depending on feel) so pin will slide in. Hope that helps - good luck.
twheelock #1031595 05/27/2014 10:37 PM
I tighten down the spindle nut tight to set bearings, then back off until I can move the washer with a small screwdriver. Then go to nearest slot for the cotter key. Works for me!
twheelock #1031671 05/28/2014 2:49 AM
Since you are going with the more modern roller bearings, you might want to check out the procedures from a more modern truck that came with roller bearings as stock.
Carl
twheelock #1031686 05/28/2014 3:48 AM
There is a different procedure for roller bearings. I read it in a shop manual but I can't figure out which one now.
twheelock #1031689 05/28/2014 3:58 AM
There is a different procedure for roller bearings. From an original 1958 Chevy truck service manual, page 3-12: On all except 2 1/2-ton models, tighten spindle nut to 33 ft-lb. torque while rotating hubs.
Also:
On models using tapered bearings, back off spindle 1/6 turn minimum and install cotter pin if aligned with hole in the spindle. If not, back off slightly until hole aligns.
twheelock #1031693 05/28/2014 4:05 AM
400 lbf-in = 33 lbf-ft
