3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1031311 05/27/2014 12:14 AM
The lead filler over the a-piller seams on my 1941 did not completely cover the seams, so small cracks were visible in the original paint where the lead did not overlap the two parts.
Can I cover over the seams with body filler and expect it not to crack, or do I need to apply more lead to fully cover the seams?
Sput #1031367 05/27/2014 2:08 AM
I would melt and remove all of the lead down to bare metal to make sure the welds underneath are sound and replace with a durable filler made for this kind of application. The old lead seems to oxidize over many decades, and I wouldn't trust it.
Sput #1031486 05/27/2014 2:18 PM
Yes, you can smooth with plastic filler over the lead and it will probably be fine if you don't want to take the time and health risk to do as suggested by Carl. I saw this topic covered on "OverHaulin" and they used a flexible filler of some sort made by 3M. The claim was it was more flexible than regular plastic filler. I think the car being overhauled was a early 70's El Camino
Sput #1031527 05/27/2014 6:07 PM
I can't picture the area you're speaking about, would it be possible to use paintable autobody caulking to fill the area?
My 46 GMC on Photobucket
Sput #1031666 05/28/2014 2:38 AM
Thanks for the suggestions. Would fiberglass reinforced filler be the type to use?
