2 members (Hotrod Lincoln, baldeagle), 83 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#1030730 05/24/2014 3:16 AM
Ok, i have a 235, from what i've found out about it, it's an early 60's.
it has a front mount on it and i was sort of thinking it should have had side mounts? Did they come with either or? Thanks,
Joe
jremig #1030786 05/24/2014 12:57 PM
Are the holes drilled in the front plate?
jremig #1030838 05/24/2014 4:15 PM
Center side mounts started in 1952 in cars and stopped in 1954(for 4 years)but were never used in trucks(the truck engines had the bosses for side mounts but were not used).
Front side mounts were used in 1955-57 cars and 1955(2nd)-59 trucks(there was no provision for center side mounts on these engines).
1958 engines saw a new upside down bolt pattern center side mount, but again, only used in cars.
Except for 1955(2nd)-59, trucks were always mounted on the timing plate
1958-59 engines are the only engines to have provisions for both center and front side mounts.
My Blog
jremig #1031324 05/27/2014 12:52 AM
Don yes they are. The engine in question has the front mount already there
