7 members (Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag),
146
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | I need to get behind the grill (but in front of the radiator) to access a fender bolt but can't figure out how to get back there. I tried going in from below by attempting to remove the "chin" panel (removed 3 bolts on each side) but can't get it loose from the grill shroud. Any advice?
BTW, when I say "chin" panel, I'm referring to this: http://www.oldchevytrucks.com/cart/product.asp?prodid=FP184&i=9915|||||
Thanks. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Lower radiator baffle. The grill on my '38 coupe is held on by screws accessed from the front through the grill slats. I don't know if that relates to your '37 truck or not.
| | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | I've removed all visible screws in the chin/lower radiator baffle but it still won't budge. | | |
