2 members (latroca52, crenwelge), 149 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,469
I need to get behind the grill (but in front of the radiator) to access a fender bolt but can't figure out how to get back there. I tried going in from below by attempting to remove the "chin" panel (removed 3 bolts on each side) but can't get it loose from the grill shroud. Any advice?
BTW, when I say "chin" panel, I'm referring to this: http://www.oldchevytrucks.com/cart/product.asp?prodid=FP184&i=9915|||||
Thanks.
Ex Hall Monitor
Ex Hall Monitor
Lower radiator baffle. The grill on my '38 coupe is held on by screws accessed from the front through the grill slats. I don't know if that relates to your '37 truck or not.
I've removed all visible screws in the chin/lower radiator baffle but it still won't budge.
