7 members (FAST55, Hanks custodian, mick53, baldeagle, 50Chevy3100, Donf, TUTS 59),
71
Mod | | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | I have a small problem. I have a 65 C60 with a drivers side rear drum that refuses to come off. It spins freely. I have tried prying, tapping with a hammer....the adjusters will not back off.They don't appear to be rusted either....any tips or tricks to get this thing off?
1965 Chevrolet C-60 292 Flatbed 2008 GMC Sierra SLE Z71 Crew Cab 1992 Chevrolet C1500 Cheyenne 5 Speed 2001 Harley Davidson FLHT Electra Glide Standard
| | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | There may be a ridge created by wear at the inside edge of the drum catching on the brake shoes. They can be a bear to get free. I have gotten them loose by removing the axle shaft and outer bearing which enables more movement to get the brake shoe past the ridge. Ugly and heavy work, eat you Wheaties before jumping into this.
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | You may try doing a bit more than "tapping" with your hammer. Try using the BFH!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Are you pulling the drum for inspection or do you have another problem with the brakes? I agree that pulling the axle and then remove nuts and outer bearing helps. | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | As of right now I'm just trying to do an inspection. I did have the axle half shaft out of the truck. However I was not able to get the outer bearing out. I could almost get it out but it would get stuck near the end of the hub. I suppose if I played with it a little more I could have gotten it out. Sounds like removing the outer bearing might help me quite a bit. So I'm going to try that. I soaked the adjusting screws with penetrating oil and ordered a brake spoon so I will try that again in a few days. For fear of warping a hard to find brake drum, I am a little reluctant to just beat on it with a sledgehammer. I was not gentle with it but I didn't beat it like a crazy person. I work in a railroad locomotive shop and am well versed in BFH, Heat it and beat it etc....lol
| | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | It is good to take it easy on the brake drum for the reasons you described. Even though it is a big chunk of metal, the edges are quite fragile. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | There is often three screws located between the studs holding the drum to the hub. Look closely they can be hard to see if the heads are full of rust and dirt. | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | Update - Was able to back off adjusters after they soaked with penetrating oil for a few days. Drum came right off.
| | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | good deal...now the fun starts | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Right on. How far you from getting those wheels on? Do you have tires yet? The money from the wheels helped to put a torklift super hitch magnum 20K receiver on the new Duramax. | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I didn't realize you had air brakes. I usually just torch the slack adjusters. Manual slacks can be bought for next to nothing these days. In fact I just recently threw a bunch of 30 year old NOS ones in the scrap iron dumpster. | | |
