| | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 55 | While I do own two Chevy trucks (56 Apache w/235 and 59 Apache w/283) I also own a 66 Caddy that had a problem that I hoped this group might find interesting.
Caddy has run great recently. Tuned up, new plugs, new carb, fuel pump, gas tank and sending unit. Its been running like a champ until yesterday when suddenly, while I was driving, it just stalled out and wouldn't start again. Checked the spark at distributor and had plenty of spark. But it wasn't getting gas. No gas was in the glass bowl of the fuel filter housing. Given all the new stuff I replaced I am stumped as to why it isn't getting gas. Tank is half full. A friend suggested vapor lock but I don't really know what that is. I also suppose that the new fuel pump could be bad. Any other thoughts? Thanks, I have always appreciated advice that I receive on this board.
1956 Apache 1959 Apache 1966 DeVille
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ray, vapor lock is when the liquid fuel in the line from the pump gets so hot it vaporizes before it gets to the carb so the engine starves - I'd suspect a new fuel pump first, seems there's a high rate of defects nowadays
Bill | | | | | Joined: Apr 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 55 | Thx Bill. I fear you may be correct. I might put the old pump back on til I get a new one. Your advice is always appreciated.
| | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | I had a similar problem on one of big trucks. The truck just stopped running, like it ran out of fuel, I still had a half of tank of fuel! I would put 5 gallons of fuel in and it started right up but when it got back to a half of tank it died again. Turns out the rubber fuel line from the tank selector valve to the fuel filter was loose. The pump was sucking air and not fuel. I guess it worked "harder" pulling up fuel from a 50 gallon saddle tank that was half full. Put a new rubber line and new clamps and problem solved. So check all your fittings.
John G 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | My experience with vapor lock has been that it is caused by poor original design (like my 83 Trans am), internal engine problem causing extreme dissipation of heat, modification of the vehicle affecting air flow, or the already mentioned fuel line/pump failure. It is pretty rare to just start to happen and other causes need to be investigated.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Make sure your gas caps are vented on these old stovebolts. And Ray Fischer your 66 Caddy may very well need a vented gas cap as well.
I had a 66 Pontiac with a 389 that would run a while and stall out. After it sat a bit it would drive a while and quit. I also replaced the fuel pump since it was not pumping fuel. New rubber lines where they were needed. Blew the lines out and could hear the bubbles in the tank.
One day I bought a new vented gas cap for it and it ran fine after that. Seems the original cap had the vent blocked by dirt.
Just another thought.
| | | | | Joined: Apr 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 55 | I'll try that as well. It usually is the simple stuff that causes problems. My first reaction is often to go for the esoteric.
