5 members (MickeyP, Oswald, Barry Martak, Jon G, moparguy), 98 guests, and 4 robots.
Topics128,088
Posts1,056,381
Members48,442
#10303 01/10/2003 12:03 AM
Tab
Offline
I have a 62 3/4 ton, long wheel base PU with a one piece drive shaft. I was told that these trucks came with a two piece dive shaft.
I had a really bad vibration and just learned that the bushing at the back of the 3sp trans was bad. I suspect that the one piece drive shaft (had it balanced a while back) created the problem but I don't know for sure.
Does anybody know for sure if this truck came with a two piece shaft?
Should I replace it with a two piece drive shaft?
delete my account and pictures
Is there a cross-member with two bolt holes about 6 inches apart just above the drive-line? (the cross-member is located just at the rear of the cab or the front of the bed)
Tab
Offline
Thanks for the reply.
I don't remember such a cross-member but I will check later today and let you know. I assume that if it exists this would be the juncture/evidence of a split drive shaft, right?
If there is evidence of a carrier mount there was a two-piece shaft. Iirc, all Chevy 3/4 tons of this vintage had two piece shafts.
Fred
52 3600
69 C-10
Tab
Offline
No carrier mount. So this means that it came with a one piece drive shaft?
The vibration was the output shaft bushing. I wonder if the long one piece drive shaft is putting to much strain on it.
Thanks for the input.
