| | | Forums66 Topics128,089 Posts1,056,366 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10303 01/10/2003 12:03 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I have a 62 3/4 ton, long wheel base PU with a one piece drive shaft. I was told that these trucks came with a two piece dive shaft.
I had a really bad vibration and just learned that the bushing at the back of the 3sp trans was bad. I suspect that the one piece drive shaft (had it balanced a while back) created the problem but I don't know for sure.
Does anybody know for sure if this truck came with a two piece shaft?
Should I replace it with a two piece drive shaft?
delete my account and pictures
#10304 01/10/2003 7:50 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Is there a cross-member with two bolt holes about 6 inches apart just above the drive-line? (the cross-member is located just at the rear of the cab or the front of the bed)
#10305 01/10/2003 4:33 PM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Thanks for the reply.
I don't remember such a cross-member but I will check later today and let you know. I assume that if it exists this would be the juncture/evidence of a split drive shaft, right?
#10306 01/10/2003 4:37 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If there is evidence of a carrier mount there was a two-piece shaft. Iirc, all Chevy 3/4 tons of this vintage had two piece shafts.
Fred 52 3600 69 C-10
#10307 01/12/2003 4:07 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | No carrier mount. So this means that it came with a one piece drive shaft?
The vibration was the output shaft bushing. I wonder if the long one piece drive shaft is putting to much strain on it.
Thanks for the input.
