| | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 22 New Guy | | New Guy Joined: Sep 2006 Posts: 22 |
'57 Big Window 3100 '53 Five Window 3100
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Snowdog,
My book of wonders says that a 6 volt battery at 100% charge should read 6.3 volts...I guess this means that 3 X 2.1 = 6.3 volts.
If you have a hydrometer, you can read the specific gravity of each cell. This simple test will find a dead or weak cell in a hurry.
Stuart | | | | | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Not that this answers your question, but I think I remember hearing of a battery that was 8 volt. It was supposed to be safe to run 6 volt equipment on and had just a little extra to make starting easier. That's just from memory though, maybe I'm wrong. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Since SAE defines a 12VDC system as having nominal voltage range of 9 to 16, it would make sense that a 6VDC system would have a range of 4.5 to 8.
Just my $0.02
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | A very long time ago, someone told me Packard used a 9v battery. I don't remember all the particulars, but should be easy enough to check if interested.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There have been similar threads on here regarding the 8-volt tractor batteries used in 6-volt applications. Seems like for some it works good for others they blow lights and fuses. | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Have you noticed that vehicle lights are now listed as 7 volts or 14 volts (not 6 and 12)? These must be the charging voltages and not the battery outputs. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
