Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Phak1, ShopRag, RLB, cmayna, Dakota Bob), 129 guests, and 2 robots.
Topics128,282
Posts1,058,492
Members48,490
is each cell 2.1 or 2.2?
'57 Big Window 3100
'53 Five Window 3100
Snowdog,
My book of wonders says that a 6 volt battery at 100% charge should read 6.3 volts...I guess this means that 3 X 2.1 = 6.3 volts.
If you have a hydrometer, you can read the specific gravity of each cell. This simple test will find a dead or weak cell in a hurry.
Stuart
Not that this answers your question, but I think I remember hearing of a battery that was 8 volt. It was supposed to be safe to run 6 volt equipment on and had just a little extra to make starting easier. That's just from memory though, maybe I'm wrong.
Since SAE defines a 12VDC system as having nominal voltage range of 9 to 16, it would make sense that a 6VDC system would have a range of 4.5 to 8.
Just my $0.02
A very long time ago, someone told me Packard used a 9v battery. I don't remember all the particulars, but should be easy enough to check if interested.
Larry
I don't own a vehicle that isn't old enough to drink.
There have been similar threads on here regarding the 8-volt tractor batteries used in 6-volt applications. Seems like for some it works good for others they blow lights and fuses.
Have you noticed that vehicle lights are now listed as 7 volts or 14 volts (not 6 and 12)? These must be the charging voltages and not the battery outputs.
