4 members (46 Texaco, TUTS 59, Peggy M, 1 invisible), 105 guests, and 2 robots.
Topics128,093
Posts1,056,480
Members48,444
#1029451 05/18/2014 12:33 PM
Can anyone tell if a 35' hand crank will work? Or what years are compatible?
That sounds about right but it depends where the first bend is. It needs to clear the bumper then 90 deg bend for handle. I've seen repops from various vendors, try The Filling Station or Chevs of 40.
1946 1/2-Ton Chevy
check the listing that Bowtie Bits has...they will be able to tell you
Ex Hall Monitor
Ex Hall Monitor
The hand crank for my '38 should be the same. I'll measure the distance from the end to the 90 deg bend and post it after I get a chance to get out to the garage.
And if it's the same as this one, you can just fab one
from three foot length of 3/4" bar stock from the
local farm supply or hardware.
http://www.pbase.com/dennygraham/image/122717525
DG
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
I forgot to go measure but Denny's pic should work for you. I don't know about the '41 but it doubles as the jack handle for my '38.
I can't access this photo. Any suggestions?
Yes, just left click on the link.
DG
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
If you're left clicking on the link and getting a message saying access is restricted or it's unsafe or basically anything other than opening the page the pic is on it's your browser settings that are interfering. If you're not getting anything at all it could be your ISP's server or some node along the way is busy. If that's the case try it again today. If you still get nothing today call your ISP's tech support.
