0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | I have a292 engine area,that I would like to use with my 55 3speed,is possible.it is for 55 panal.thanks | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Questions to ask, Do I want to make up new motor mounts? Can I find a bell housing that fits the 292 and the 55 three speed, Can I mount this bell housing into the panel truck? Will the drive shaft need to be changed? Will the radiator and hoses match up? Do I want to do this much to make it all work? One at a time and then decide.
Steve H
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Yes, it's been done many times. A search should turn up detailed info. All of Steve's post applies to your situation. The 55 trans should bolt up to the 292 but the 292 is a torque monster and the later (67?) and up fully synchronized 3sp would hold up a lot better. Use side mounts (Chassis Engineering) along with the trans mount; do NOT mount the engine on the front and trans on the back---it's too much strain on the bellhousing. I guess it comes down to your skills and equipment, it's not a weekend swap.
Evan
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Use side mounts (Chassis Engineering) along with the trans mount; do NOT mount the engine on the front and trans on the back---it's too much strain on the bellhousing. Why would this be when the original was mounted this way? Do you say this due to the increased power/torque of the 292? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | The bell housings are different. The original engine/trans combination the mounts were on the front of the engine and on the bellhousing, none under the transmission. The later engines (230/250/292) had side mounts and the 292 is different in that the mount on the passenger side is more to the front of the motor. However if you can find a bellhousing from a later 6cyl or v8 truck, it will bolt to the original crossmember and you will be ok.
Tommy 59 apache 1/2t 261 short stepside | | |
