3 members (Peggy M, 2 invisible), 58 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1029427 05/18/2014 4:16 AM
I have a292 engine area,that I would like to use with my 55 3speed,is possible.it is for 55 panal.thanks
johnhull #1029456 05/18/2014 12:48 PM
Please clarify your post
johnhull #1029520 05/18/2014 6:33 PM
Questions to ask, Do I want to make up new motor mounts? Can I find a bell housing that fits the 292 and the 55 three speed, Can I mount this bell housing into the panel truck? Will the drive shaft need to be changed? Will the radiator and hoses match up? Do I want to do this much to make it all work? One at a time and then decide.
Steve H
johnhull #1029539 05/18/2014 7:32 PM
Yes, it's been done many times. A search should turn up detailed info. All of Steve's post applies to your situation. The 55 trans should bolt up to the 292 but the 292 is a torque monster and the later (67?) and up fully synchronized 3sp would hold up a lot better. Use side mounts (Chassis Engineering) along with the trans mount; do NOT mount the engine on the front and trans on the back---it's too much strain on the bellhousing. I guess it comes down to your skills and equipment, it's not a weekend swap.
Evan
coilover #1029719 05/19/2014 4:04 PM
Why would this be when the original was mounted this way? Do you say this due to the increased power/torque of the 292?
johnhull #1029740 05/19/2014 5:18 PM
The bell housings are different. The original engine/trans combination the mounts were on the front of the engine and on the bellhousing, none under the transmission. The later engines (230/250/292) had side mounts and the 292 is different in that the mount on the passenger side is more to the front of the motor. However if you can find a bellhousing from a later 6cyl or v8 truck, it will bolt to the original crossmember and you will be ok.
Tommy
59 apache 1/2t
261 short stepside
