4 members (Rich'sToys, Bill Hanlon, klhansen, 1 invisible), 55 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#1029424 05/18/2014 3:55 AM
My 1959 TF 38 flatbed has a shopbuilt two cylinder hoist. One of the cylinders is in the shop being rebuilt, Reinstallation will require refilling the pump reservoir. Does anyone know what kind of oil I should put in the pump/reservoir? Hydraulic oil, motor oil, or ??
I couldn't find a mfg name on the pump/tank. It is PTO driven and the pump is located inside the tank (reservoir).
Any help will be appreciated.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Not that I can help you with your case but the plow on my old Willys Jeep runs ATF off a belt driven pulley. Someone with knowledge will chime in.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Moderated by  Dusty53
