1 members (Wooley), 105 guests, and 0 robots.
Topics128,151
Posts1,056,997
Members48,460
#1029582 05/18/2014 11:13 PM
Ok calling all 1937 trucks on the front fenders at the lower crowl where fender meets the running boards what are you using to fill in the gap and what color are you to paint that material thanks pierce
peter foster
Need picture of the air vent assy handle position and does a 1937 use a spring and bracket thanks pierce
peter foster
On the fender question, I used fiberglass fenders so mine don't fit all that well. I don't believe there was anything between the cowl area and fender. Same for fender to running board. Around the front core support and fender, there is cloth covered bead used. It's the same material used around the rear fenders to bead seam.
All trucks used black fenders and running board, no matter what color truck body was. The exception was special order commercial use trucks painted to the customers specific color combination. The head light buckets were also painted black.
The cowl vent does use a spring to index it. I will try to get a picture of mine, send me a private message with your e-mail address so I can send pictures to you.
Joe
