7 members (55shaker, dt235sd, Hanks custodian, NJC, 3B, Gdads51, 1 invisible),
211
Mod | | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | So I took out my transmission and drive shaft about a year ago in order to upgrade to an NV4500 and then life got in the way (baby and all that that incurs  ). Anyway, we are moving at the end of the month and I just put the original transmission back in to button everything up. Problem is is that it feels as if the clutch is engaged, even in neutral. I used the old clutch disc and pressure plate as the truck shifted great before I took it apart. I got a new throw-out bearing because I left the old one out and it got ugly. I can see the linkage "bucking" when I try to start the truck and see the transmission rotate even though I am in neutral. What could cause this issue? Any help would be greatly appreciated. Thank you.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Is the disc in backwards? It could be interfering if installed backwards. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Did you compare the new throw out bearing to the new one to make sure it was the correct length? | | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Just got back to the house after church and shopping (Sunday is our grocery day as it is the only day we go to the "city")
I'm removing the transmission now. I think I might of put the friction plate on backwards.
I'm pretty sure they are the same length, I already threw out the throwout bearing.
Will let you know when I am done. Thanks! | | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Okay, the friction plate is installed correctly, it looks like the TO is hitting the pressure plate. I have a 3 finger BW. From what I found, I might have the wrong TO bearing. Off to the parts store. Thanks everyone.
Side note, my fork retaining spring just broke when I was pullung the transmission out again so this will have to wait till Wednesday now.
Thanks all! | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Which one do you need. I've got a long new one you can have. I'm in Richmond.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Larry,
Thanks for the offer, but it looks I need the shorter one. Luckily, advance auto parts had one in stock, go figure. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have some NOS retaining springs if you want one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Thanks Wrench, but I already have some on order. They should be in by Wednesday. I really appreciate everyone's helpfulness. | | |
