0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 23 New Guy | | New Guy Joined: Aug 2001 Posts: 23 | I was about to install my new amp gauge and was trying to remeber is there a cardboard insulator on both side of the gauge bolts. Cleaned and painted my gauge case last year and forgot to note any insulators on the mount studs
sader dog
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I beleive the insulators are on both bolts, the bottom side only, The nut makes the contact. | | | | | Joined: Aug 2001 Posts: 23 New Guy | | New Guy Joined: Aug 2001 Posts: 23 | The rebuilt gauges Amp, and fuel came back without any insulators was the reason for my post. So as you wrote I will make sure that the bolts do not contact the metal case right? Thanks, my problem is this old girl is a project on going for the past 6 years, love it
sader dog
| | | | | Joined: Aug 2001 Posts: 23 New Guy | | New Guy Joined: Aug 2001 Posts: 23 | Thanks guys for your input. I did a stupid thing over the weekend and rushed the install of the gauges. Thinking that the gauges were insulated as you noted Denny, I put the power to the system, and melted the temp gauge tube....the gauges are not insulated from the case. The need for the paper is to insulate. I should have known this as I have been involved with trucks all my life, just got away from them the past few years, so if you work on new gauges be sure to use the insulating paper, not always sent with these gauges.
sader dog
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Another reason for the for the temperature tube to melt is that it was the only ground path. You need a better ground than the temperature tube to the instrument cluster for the fuel gauge to work well. | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Originally posted by Baldy: Another reason for the for the temperature tube to melt is that it was the only ground path. You need a better ground than the temperature tube to the instrument cluster for the fuel gauge to work well. run a ground strap from the engine to the firewall, be sure the dash panel is well grounded to the firewall, and run a ground strap from the battery to the engine and also the frame. Clean the mounting for the alternator or a ground wire from the alternator.
"It ain't a truck if you can't hose out the cab."
