1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | My '65 C20 has recently developed a "banging" sound which seems to be coming from the driver's side front. A local mechanic (who is not an "old car" mechanic) listened to it and said he thought it was some sort of bushing. The sound only occurs when driving on rough terrain (dirt driveway or town roads). Does anyone have any ideas what the source could be?
1965 Chevy C20 Stepside
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Probably a shock bushing or the upper shock mount bolt is loose in the frame. If it has a sway bar it could be a sway bar bushing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thank you. I will check those.
| | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | Reminds my of a time many years ago when a coworker came in and said he had a noise in the back of his car, and the dealer said he needed a new axle. He wanted another opinion. Two of us took it for a drive around a large pot holed parking lot across the street. When we started to hear the noise, I got in the back seat to listen closer. The noise was definitely there, so we put it on the lift for a look see. Found a stone wedged in the frame. Took it out and all was well. He was most thankful.
| | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I will look for that as well. Thanks.
| | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | could also be upper control arm bushings, look for the rubber part looking extruded out of steel part and being all dry rotted. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 |
