Brrrr
place holder
0 members (), 136 guests, and 2 robots.
Topics128,274
Posts1,058,431
Members48,489
Hi all,
I have a 52 Chevy pickup 3100 with a leaky trans. It is drippy enoughy to cause OJ concern. Right where the yoke fits into the tranny. Any thoughts on a fix without having to pull it out? A rope seal perhaps? just wanna slow it down.....
Thanks for the help.
The only dumb question is the one not asked.
Take care,
Steven
No one can drive us crazy unless we give them the keys.
Have you changed to an open driveshaft? If so the seal can be had at NAPA and it is not too hard to change. Undo the U-joint and there is a bolt holding the yoke on. Pull the yoke and replace the seal. Same as a 55 to 57 I would think.
Steve H
Steve H, what open drive transmission has a bolt-on yoke? I thought they had splined slip yokes. 52 Stove, we need to know what transmission you have.
Carl
Its the original 4 spd on the floor, solid drive line and rear end.
Thanks!
Take care,
Steven
Torque tube equipped transmissions are supposed to leak from the transmission into the universal joint ball. That is how the u-joint gets lubed.
Carl
Are you missing the gasket/o ring that that goes between the ball and the collar assy?http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0712.htm
Ed
Ed
On the open drive shaft the yoke has splines,and there is a bolt that holds it in the center of the tail-shaft. On the closed system it will leak as described above. There is no seal at the tail-shaft in that system. There is a compression seal at the end of the "ball" housing and a set of gaskets with shims that seal and adjust the ball to the transmission. The procedure in the manual posted above works.
Steve H
At least that is what was on my friends 57 1/2 ton when we replaced the seal on the yoke.
Steve H
Thanks all.
Is there a good parts place to get the kits from? none re-pop/reproduction china type if possible?
I'll pass this along ....
Take care,
Steven
