8 members (52Carl, Steelonsteel, TexasFarmTruck, Samantha, TUTS 59, Shade Baby, TexasJim50, Jims46),
87
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 107 Shop Shark | | Shop Shark Joined: May 2009 Posts: 107 | Hi all, I have a 52 Chevy pickup 3100 with a leaky trans. It is drippy enoughy to cause OJ concern. Right where the yoke fits into the tranny. Any thoughts on a fix without having to pull it out? A rope seal perhaps? just wanna slow it down.....
Thanks for the help. The only dumb question is the one not asked.
Take care, Steven No one can drive us crazy unless we give them the keys.
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Have you changed to an open driveshaft? If so the seal can be had at NAPA and it is not too hard to change. Undo the U-joint and there is a bolt holding the yoke on. Pull the yoke and replace the seal. Same as a 55 to 57 I would think.
Steve H
| | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Steve H, what open drive transmission has a bolt-on yoke? I thought they had splined slip yokes. 52 Stove, we need to know what transmission you have. Carl
| | | | | Joined: May 2009 Posts: 107 Shop Shark | | Shop Shark Joined: May 2009 Posts: 107 | Its the original 4 spd on the floor, solid drive line and rear end.
Thanks!
| | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Torque tube equipped transmissions are supposed to leak from the transmission into the universal joint ball. That is how the u-joint gets lubed. Carl
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Are you missing the gasket/o ring that that goes between the ball and the collar assy?http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0712.htm
Ed
Ed
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | On the open drive shaft the yoke has splines,and there is a bolt that holds it in the center of the tail-shaft. On the closed system it will leak as described above. There is no seal at the tail-shaft in that system. There is a compression seal at the end of the "ball" housing and a set of gaskets with shims that seal and adjust the ball to the transmission. The procedure in the manual posted above works.
Steve H
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | At least that is what was on my friends 57 1/2 ton when we replaced the seal on the yoke.
Steve H
| | | | | Joined: May 2009 Posts: 107 Shop Shark | | Shop Shark Joined: May 2009 Posts: 107 | Thanks all. Is there a good parts place to get the kits from? none re-pop/reproduction china type if possible? I'll pass this along ....
