| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 12 New Guy | | New Guy Joined: Jun 2005 Posts: 12 | What (year and car or truck) will a 1956 Chevy car manual 3 speed transmission fit?
| | | | | Joined: Jun 2005 Posts: 12 New Guy | | New Guy Joined: Jun 2005 Posts: 12 | What engines will a 1956 Chevy starter, from a 235 6 cylinder and manual 3 speed, fit? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | That trans will fit bellhousings on all pass cars from 55 on, truck about 48 on. Starters need to be kept with original flywheel, all 235s will fit all chevs from 37-62. A 37 for example can go with later 235s just keep all original parts from bellhousing back. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the starter from a 56 235 will fit any 12V 235 [55.2 up], as Jim sez the starter and flywheel need to match
Bill | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | FYI, re. your 37 pickup, I want to clarify, you can make just about any trans/engine etc fit your truck. But you need to decide if you want to gut the entire drive train or just swap the engine. Bottom line, there are many solutions to your questions depending on what you want to have in the end. Best of luck Jim | | | | | Joined: Jun 2005 Posts: 12 New Guy | | New Guy Joined: Jun 2005 Posts: 12 | Thanks for the information. | | |
