2 members (JeffA, FishinToms53),
170
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | CAN any one tell me where to purchase a throttle plate for a model b rochester with 2/15/16 inch oc stud hole BASE. THE OLD PLATE HAD A 51 on it and i think i threw it out with a wad of paper towels. CHRIST I HOPE I CAN GET A NEW ONE, been looking -NO LUCK HELP!!!!!!!!!!!!!!!!!Thanks for any info. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I have a couple of old Rochesters laying around. I'll see what the bore is and let you know in the morning.
| | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | THANK YOU SIR, I CANNOT BELIEVE i did this. GUESS I AM GETTING OLD AND STUPID. THANKS | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I have the whole throttle body assembly with the 2 15/16 bolt pattern. Sitting here in front of me. I don't see any number on the plate, but there is number on the body. 23013. Will that work? | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | If Roy's item doesn't work for some reason, give me a shout. I know I've got at least one junk Rochester B, and maybe a couple of others. You're welcome to the whole thing if you need it. Jerry
| | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | THANK YOU FOR TAKING THE TIME TO FIND THE BASE.THE ONE I HAVE HAS ONLY 22 stamped near the throttle shaft hole where the butt end is on the shaft not the linkage connect side . IF it is 2/15/16 it should work.WHAT DO YOU WANT FOR THE BASE ? THANKS | | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | THANK YOU FOR THE FEEDBACK ,I WOULD LIKE TO BUY THE CARB FROM YOU, IF IT IS A 2/ 15/16 base.I DO NEED A PARTS CARB. THANKS | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Just send me a mailing address and I'll ship it to you. Others have helped me, and since I may not ever need it I need to get it to some one that might. Send me private message with your address so I can get it in the mail.
If it's right and will work, then that will be great. If not, then maybe some one might need one eventually. But it's yours for the taking. No money involved.
| | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | DO YOU HAVE DUNKIN DONUTS SHOPS near you? | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 |  Afraid not.  But that's okay. Send me an address so I can get this off to you. Just glad I have something that might help. | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Ditto for me- - - - -I've been on the receiving end of plenty of freebies from members here. PM me an address and I'll box up the bits and pieces for you. Jerry
| | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | address sent. I hope i did it right | | | | | Joined: Nov 1995 Posts: 5,733 24601 | | 24601 Joined: Nov 1995 Posts: 5,733 | And that's what it's all about!
Thanks for exemplifying the vision of Stovebolt.com, Gentlemen -- I hope George Mills and Tom Brownell are smiling down on us!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | No address in my private message box. You can e-mail me at [email protected] | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | BJF52 I sent you a private message. You can check it by going to the top of the page where there is a section called "My Stuff". Should be flashing a message at you. Click that flashing link and you can respond to my message. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | don't feel bad... I heard a story once, some fellas used a big metal drum as a trash can at a shop... one day they set a rear end on it, took out the guts of the pumpkin doing a ring & pinion repair or some sorta maintenance, they put the guts in the trash can it was sitting on and went to lunch.
They came back from lunch, and while they were out the janitor had emptied out the trash cans and the dumpster had just been emptied by the big garbage truck!
ooops.
We all do stupid/silly things with our trucks.
-W | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | I just sent you a PM, also. Either reply there or to my email with a mailing address. Jerry
| | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | HOPE ADDRESS GOT TO YOU sent it back on PM reply. THANKS | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Got it! Parts will be on the way shortly. Jerry
