2 members (Scott '48 2ton, dgrinnan), 141 guests, and 2 robots.
Topics128,163
Posts1,056,962
Members48,458
CAN any one tell me where to purchase a throttle plate for a model b rochester with 2/15/16 inch oc stud hole BASE. THE OLD PLATE HAD A 51 on it and i think i threw it out with a wad of paper towels. CHRIST I HOPE I CAN GET A NEW ONE, been looking -NO LUCK HELP!!!!!!!!!!!!!!!!!Thanks for any info.
I have a couple of old Rochesters laying around. I'll see what the bore is and let you know in the morning.
THANK YOU SIR, I CANNOT BELIEVE i did this. GUESS I AM GETTING OLD AND STUPID. THANKS
I have the whole throttle body assembly with the 2 15/16 bolt pattern. Sitting here in front of me. I don't see any number on the plate, but there is number on the body. 23013. Will that work?
If Roy's item doesn't work for some reason, give me a shout. I know I've got at least one junk Rochester B, and maybe a couple of others. You're welcome to the whole thing if you need it.
THANK YOU FOR TAKING THE TIME TO FIND THE BASE.THE ONE I HAVE HAS ONLY 22 stamped near the throttle shaft hole where the butt end is on the shaft not the linkage connect side . IF it is 2/15/16 it should work.WHAT DO YOU WANT FOR THE BASE ? THANKS
THANK YOU FOR THE FEEDBACK ,I WOULD LIKE TO BUY THE CARB FROM YOU, IF IT IS A 2/ 15/16 base.I DO NEED A PARTS CARB. THANKS
Just send me a mailing address and I'll ship it to you. Others have helped me, and since I may not ever need it I need to get it to some one that might. Send me private message with your address so I can get it in the mail.
If it's right and will work, then that will be great. If not, then maybe some one might need one eventually. But it's yours for the taking. No money involved.
DO YOU HAVE DUNKIN DONUTS SHOPS near you?
ohwell Afraid not. cool But that's okay. Send me an address so I can get this off to you. Just glad I have something that might help.
Ditto for me- - - - -I've been on the receiving end of plenty of freebies from members here. PM me an address and I'll box up the bits and pieces for you.
address sent. I hope i did it right
24601
24601
And that's what it's all about!
Thanks for exemplifying the vision of Stovebolt.com, Gentlemen -- I hope George Mills and Tom Brownell are smiling down on us!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
No address in my private message box. You can e-mail me at [email protected]
BJF52 I sent you a private message. You can check it by going to the top of the page where there is a section called "My Stuff". Should be flashing a message at you. Click that flashing link and you can respond to my message.
Socket Breaker
Socket Breaker
don't feel bad... I heard a story once, some fellas used a big metal drum as a trash can at a shop... one day they set a rear end on it, took out the guts of the pumpkin doing a ring & pinion repair or some sorta maintenance, they put the guts in the trash can it was sitting on and went to lunch.
They came back from lunch, and while they were out the janitor had emptied out the trash cans and the dumpster had just been emptied by the big garbage truck!
ooops.
We all do stupid/silly things with our trucks.
-W
I just sent you a PM, also. Either reply there or to my email with a mailing address.
HOPE ADDRESS GOT TO YOU sent it back on PM reply. THANKS
Got it! Parts will be on the way shortly.
