Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (UtahYork, Pre '68 Dave, rfs56trk, Donf, Oldcaliforniakid, baldeagle, J Lucas, Nick in Manitou, Rusted Nut), 36 guests, and 1 robot.
Topics128,005
Posts1,055,253
Members48,418
#1028094 05/12/2014 2:21 PM
1959 235 engine, why does it have 2 threaded holes on passenger side that enter oil galley? I'd installed a motor and didn't recognize what the holes were for (nothing was in them) and I figured they were to hold a coil bracket. Imagine my surprise when I started putting oil in the engine and these 2 holes began weeping oil! Afterwards I had to wonder, what are they for, the remote oil filter cannister things are always on driver side of engine, these holes on opposite side? Just curious why they are there???
lefty1 #1028137 05/12/2014 5:03 PM
lefty1,
Can you post a link to a photo of that side of the engine?
People will speculate about what you are referring-to, but you'll get more useful/helpful answers if you can link to a photo.
In the top middle of the passenger-side of the head is a hole and a plug (normally, a plug). People sometimes remove the plug and attach a line from an oil filter fitting on the driver's side of the block (a jury-rig solution to minimal oil reaching the rocker arms).
lefty1 #1028139 05/12/2014 5:09 PM
The bolt holes where the coil bracket mounts do penetrate through into the area where oil drains back to the crankcase. If bolts aren't in those holes a small leak can happen on occasion. It isn't pressurized oil, just gravity flow back to the oil pan. Either bolt the coil where it belongs or just plug up the holes with short bolts.
lefty1 #1028167 05/12/2014 7:07 PM
A picture please. Holes in the head covered above. Holes in the block? Cover? where are the holes?
Steve H
lefty1 #1028184 05/12/2014 8:40 PM
Steve H
Jerry nailed it.
But a pic is worth a thousand words.
Those are the drilled and tapped holes for the coil bracket.
regards,
steve sr.
lefty1 #1028594 05/14/2014 5:34 PM
There are two holes low just above the oil pan on the passenger side which go all the way through to the crankcase. they are for holding the sheet metal piece with a sort of filter which is where the draft tube comes out. If you don't put bolts back in it will leak while the engine is running and drive you crazy looking for a leak. Larry
58 gmc 100 with 350 sbc
