| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 16 New Guy | | New Guy Joined: Jun 2013 Posts: 16 | Good Morning,
Does anyone know a good trick to removed the heater knobs from a deluxe heater control in a 66 c10? Is there a way to remove them and salvage them for re-use?
Thanks and Happy Easter! | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | You might want to try heating them with a blow-drier and then using pliers to pull them off. Of course you would want to wrap a small rag around them to keep from leaving plier marks on them. | | | | | Joined: Dec 2013 Posts: 23 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 23 | They don't cost much to replace if you don't succeed
Bob
| | | | | Joined: Jun 2013 Posts: 16 New Guy | | New Guy Joined: Jun 2013 Posts: 16 | Well, I succeeded at breaking off two of the control arms where the metal inserts into the plastic knobs. Anyone have any good suggestions to repair the control arms or any idea where I can find replacements? Thank you. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check the links section and investigate vendors near you, any of them that cover the years will have them
Bill | | |
