| | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | has anyone found a good source for 1 ton parts? I badly need a hub grease cap, but the size is so odd apparently. I'm trying to get the truck ready for a 4,000 mile road trip and I need to do some work thanks! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy seetz, Is the cap you're looking for the one with eight sides at the outboard end and a very fine thread at the other end? If that is the cap, then it is the same cap that is used on up to 1 1/2ton trucks of the same era. | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | no, it's a very boring round cap with a little rim. the problem is that where it gets pushed in the hub, it's almost 2 1/4 " wide, and it's 1 3/8 " deep, which apparently is an impossible size to find (for me at least) | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy seetz, send me a p.m. with your address and I'll see if I can find one. | | |
