3 members (jmoore, gswbbc, Lightholder's Dad), 67 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
I am pulling the 6 cyl. out of a '62 C-10 and will install a v8 using a Hitachi block mounted mini starter. Problem: the original starter had 3 leads; one for the battery cable, and two leads on the solenoid, one of which had a purple wire and the other lead had a white and red (?) wire. Problem: the mini starter only has two leads; one for the battery cable and one on the solenoid. How do I hook the mini starter up, since I guess I am not going to use one of the original leads ? Thanks in advance.
Riding in the Passing Lane
Hook the bat. cable to the big post naturally. The purple wire is the start wire from the ign. switch or neutral switch. It will hook to the small term. on the solenoid. The other wire is a resister bypass. If you are using HEI you don't need it. If you are using points you may get by without it. You can use a Ford type solenoid as a relay & get the bypass off it. Some ign. switches have a term on them for bypass.
1972 Chevy c10 Cheyenne Super
