| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Would someone kindly give me a hand installing the clutch?
Which way does the clutch disc go in? If I am reading the manual correctly the nipple side goes towards the flywheel.
I am installing an engine from a '51 car into my '52 truck and it looks like the car owner had the clutch the other way around. And also they used the wrong flywheel bolts and ground off the heads and ruined the clutch disk.
Many thanks! | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | on one side of the clutch disc, towards the center (at least on mine) it should say "Flywheel side". It'll be small lettering, and might be hard to see... so take a long close good look at it!
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The spring hub sticks out more on one side of the disc than the other. The side that sticks out more goes towards the pressure plate.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | OK, thanks! Got it. Sure enough mine also has small lettering. | | |
