1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1027380 05/09/2014 4:09 PM
Would someone kindly give me a hand installing the clutch?
Which way does the clutch disc go in? If I am reading the manual correctly the nipple side goes towards the flywheel.
I am installing an engine from a '51 car into my '52 truck and it looks like the car owner had the clutch the other way around. And also they used the wrong flywheel bolts and ground off the heads and ruined the clutch disk.
Many thanks!
on one side of the clutch disc, towards the center (at least on mine) it should say "Flywheel side". It'll be small lettering, and might be hard to see... so take a long close good look at it!
The spring hub sticks out more on one side of the disc than the other. The side that sticks out more goes towards the pressure plate.
My Blog
OK, thanks! Got it. Sure enough mine also has small lettering.
