3 members (stlcardinalsguy, dunfire, Otto Skorzeny), 110 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
This is on a '56 GMC 1-Ton.
'56 1-ton disk brake conversion
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
Interesting I wondered if that couldn't be done the other day. Less wheel rub issue maybe. I wonder what brakes were used.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
Chevy 3/4 ton K series (4x4) front brakes
'71-'86 3/4 ton K series rotors
'71-'78 3/4 ton K series calipers & brake lines
Later calipers went to metric size hose connection.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
Where did you get the bolt spacers and rotor spacers? Why did you not just go with larger bolts through the rotor and drill the hub? Is the center ring even necessary?
A local machine shop made the parts for me.
Larger bolts with larger nuts would interfere with the outer diameter of hub casting just inboard of the brake flange.
The ring keeps the rotor concentric with the hub.
I checked the clearance between the rotor bolts in the original application and the the rotor bolt hole diameter and found it pretty loose. It looked like the factory used the center bore to keep it centered so I just did the same.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
What is the thickness of the steel plate?
What size bolts for rotor?
The plate is 1/2 cold rolled steel. The mounting tab on the bottom is offset 1/2" using a piece of 1/2" square stock welded between the tab and the main plate.
When I had the plate cut, I made the tab 1/2" longer so that it would overlap the main plate. I bolted the main plate to a spindle and the tab where it went and then placed the piece of square stock in between and tack welded it. There are 4 separate beads of weld holding the tab on so I don't think it will go anywhere.
The bolts holding the rotor on are the same thread size as the studs that held the drum on but longer to fit the rotor.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
John, Have you considered selling the unique parts that you have designed. I would be interested in purchasing a "adapter" parts kit. My 55 1 Ton would be a perfect candidate for upgrading.
Thanks in advance. Howie near Calgary
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Do you have any dimsioned drawings for the mounting plates. CAD drawings etc.
Yep, I'd be interested as well. Looks like a well thought out job, thanks for sharing!
V
VEW Offline
V Offline
Starting to work on the '59 now, as Chief has been sitting waiting patiently long enough. Saw this thread about converting the disc brakes. Are there any updates to this that anyone knows about?
Saw somewhere that someone makes a bracket for AD, but don't know about TF.
Thanks for you help.
~ Victor
1957 3100 - moved on
http://www.hollisterroad.com/
I think the link above should be a lot of help in your search for a braking system.
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
V
VEW Offline
V Offline
Thanks alot MikeC...exactly what I was looking for.
Have you or do you know anyone that has used this kit?
~ Victor
Moderated by  Dusty53
