2 members (dt235sd, Jon G),
50
Mod | | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | I am in need of a radiator for my C60. Where could I possibly find one? I did some searching and they seem pretty hard to find. 1965 C60 292
1965 Chevrolet C-60 292 Flatbed 2008 GMC Sierra SLE Z71 Crew Cab 1992 Chevrolet C1500 Cheyenne 5 Speed 2001 Harley Davidson FLHT Electra Glide Standard
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I don't know what the wrecking yard situation is like where you live but here if you go into most of them they have some kind of database where they can pull up these things. Once located you can have it shipped in from wherever, you know how much for the part and the shipping so you can make a decision. Good luck in your search. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | If there's an oldtime radiator shop in your area, most of them can swap tanks and side brackets from a slightly different radiator to fit your application. Do you have an original radiator to work with, or are you filling a big empty hole? Jerry
| | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | I do have the radiator. I took it to the only local shop that I know of around here that will service radiators and they quoted me almost $800 to recore the radiator. To me that just seems extremely high.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Check this out and see if he has a radiator: Parts Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | After some research I found a guy that will take car of the recore for me for a reasonable price. Thanks for your help.
