4 members (greenie-reddy, Jon G, cmayna, dt235sd), 26 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
#1026906 05/07/2014 4:28 PM
I
I Offline
I am in need of a radiator for my C60. Where could I possibly find one? I did some searching and they seem pretty hard to find. 1965 C60 292
1965 Chevrolet C-60 292 Flatbed
2008 GMC Sierra SLE Z71 Crew Cab
1992 Chevrolet C1500 Cheyenne 5 Speed
2001 Harley Davidson FLHT Electra Glide Standard
I don't know what the wrecking yard situation is like where you live but here if you go into most of them they have some kind of database where they can pull up these things. Once located you can have it shipped in from wherever, you know how much for the part and the shipping so you can make a decision. Good luck in your search.
If there's an oldtime radiator shop in your area, most of them can swap tanks and side brackets from a slightly different radiator to fit your application. Do you have an original radiator to work with, or are you filling a big empty hole?
I
I Offline
I do have the radiator. I took it to the only local shop that I know of around here that will service radiators and they quoted me almost $800 to recore the radiator. To me that just seems extremely high.
Check this out and see if he has a radiator:
Parts
Harold
Harold
I
I Offline
After some research I found a guy that will take car of the recore for me for a reasonable price. Thanks for your help.
