| | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | I am getting ready to remove the cab from my 46 chevy 3/4 ton and would like to unfasten the steering mast from the gear housing. Is there an easy way other than taking off the gear box from the frame and removing pitman arms and the other related stuff. I can fiddle with the gear box and linkage later as I merely want to get the steering wheel and it's shaft our of my way so I can unbolt the cab and remove it to a dolly. thanks, lane
sweetpealane
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It comes out as an assembly. No shortcuts unfortunately.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I can fiddle with the gear box and linkage later as I merely want to get the steering wheel and it's shaft our of my way so I can unbolt the cab and remove it to a dolly. You can remove the cab without removing the steering and pedals. Unbolt the cab, dash braces, take loose the wires, remove the toe & floor board and lift the cab off the truck. Cab off frame Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I removed the whole gearbox , no big pro. I was told to remove the steering mask was not the best way .
" STUCK IN THE '50'S "
| | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | thanks everyone for your input .... I plan to get 4 men and lift the cab just enough to clear the rear wheels and put it on a dolly nearby (I saw this done on AD truck in a video on the bolt) ..... everything else is off the truck and out of the cab, except for the steering wheel which would make it harder to lift over without a hoist .... again, thanks
lane
sweetpealane
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | Loosen the frame mounts on the steering gear box along with the under dash mount. This will let the mast lay down so the you don't need to lift the cab as high to clear the shaft.
joe | | |
